Press fit assemblies in Ansys DesignSpace
wlennard
Automotive
GB
Does anyone know how or if Ansys designspace 9 can simulate interference fit of 2 parts, this could either be press fit or shrink fit.
I have had a look and read but cant find it anywhere.
regards
Will
Yes it will. You'll need the correct license to be able to use the appropriate options to enable the model to be solved correctly though (initial penetration, for example).
See faq569-1083 for details on how to make best use of Eng-Tips.com
thanks for the pointer, i presume the option that we require would be 'initial penetration'?
Yes. It's a contact setup option you need to set ("Include initial penetration" I think is how it is labelled in the options list in Workbench).
