PREPRIN Error in input file
SM1994
Bioengineer
NZ
Hello
I am trying to run a job by importing the INP file.
but I face the following error:
I use Abaqus/Explicit in case it matters.
Does anyone know how to resolve ir?
There’s no error here, just some harmless warnings. If that’s the whole output when you import inp file then everything is fine.
If you want to run that simulation, then you shouldn't import it into Abaqus/CAE.
Either submit the input file from a command line or open A/CAE, go into the Job-Module, create a new job and choose as source this input file.
Thanks but unfortunately it is the only thing that I get.
I am using command line, for submitting the job.
I try other methods to sort it out.
