Hi everyone! I have a problem with a FEM analysis, and as I am very new in the field of Patran/Nastran I am a Little bit lost.
The objective is to study the stresses that suffers a seal ring installed inside a cylinder due to thermal expansion. In order to do that, I have to first apply the radial load that the outer cylinder transmits to the seal ring, so the ring has a certain compression. Then, I have to increase the temperature so as to study the thermal expansion of the ring. The problem is that for doing the first step, there is no constraint in the outer contour of the seal ring, and for applying the temperature I have to restrict the radial movement for the outer contour of the seal ring.
I do not know if it is possible to 'save' the stresses and displacement of the first case so I can introduce it on the second problem without the load and with the radial movement restriction. Maybe is there a simpler way of doing this analysis, but my knowledge is limited.
Thank you very much!
