precision
  • Thread starter Thread starter sreenivasan_BH
  • Start date Start date
S
sreenivasan_BH
Guest
hai everbody
i am facing a problem to show the dimension
as xxx.000 not as xxx
i am adding .000to the dimension in dim., properties
if i give decimal places to 3 then also i am not getting the result
can any body help me
thanks
from,
sreenivasan
There is an option in the drawing.dtl file for suppressing trailing zero's, this may be the problem - I'll look up the actual parameter & post it when I find it.
hellow
some has told
they will reply solution for the problem
please reply soon
thank you
sreenivasan
Hi Sreenivasan,</PRE>In the drawing mode, Advanced
