M
Mikeyz
Guest
I have a dimension that is rounded to whole mm now i want that dimension to be toleranced to 0.2 mm,
but every time I regenerate the precision on the tolerance gets changed to whole mm.
the precision changes from 0.1 or 0.12 to 0.
While this is true for some of my dimensions for others it doesn't change and it keeps the precision I
manually gave the tolerance.
EDIT: i found the a workaround ,when i make the dimension have the tolerance set to none instead of
general it will keep the precision.
