Please see attached typical detail below.
My question is the following.
Is the idea in terms of the support of the beam, for its bearing area to be that of the precast beam supported on the corbel, or is the corbel just to support the beam until the cast-in-place closure is poured?
If that is the case is the reaction from the beam considered centered in the column because of a compression strut or is it through shear friction between the precast beam and the cast-in-place pour?
