Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Then do your calculations. You're likely to find that the building doesn't work for current loads, nor did it work for its original design loads. So now you wonder if you made an analysis mistake, a loading mistake, a measuring mistake or maybe the materials were stronger than you assumed.
