I am experiencing the following situation: a 480/208-120V (delta-wye) transformer was used to step up voltage for 480V equipement. As such, 208-120 became primary, neutral x0 being connected as well to the neutral of the installation. Other single phase loads (and possible three phase) were connected to the 120/208 as well. After approx. one year, the neutral wire was found completely burned.
What is the difference if x0 is not connected to the system's neutral? In other words, would the wye connection generate such an unbalanced current to effectively burn the neutral?
