Power consumption of Vacuum Pumps
DrSmile
Chemical
Jun 5, 2006
12
Hello Everyone,
I am trying to develop a process involving calcination of limestone under low pressures. Before i go further i need to know if it is worth it, ie. the cost of vacuum pumping.
The pressure working range would be around 10-100 mbar (abs).
I could use Rotary Vane or Liquid Ring pumps, depending on the cost.
So the question i have is : does anyone know a rough figure correlating the power consumption of a Vacuum pump to it's displacement volume, at larger scales (>40m3/min)?
A figure even for smaller scales would do for a first approach.
I have a curve for a 150 hp pump that predicts 2880 cfm capacity with 90 deg F inlet gas temp and 70 deg F seal water. The capacity is very much dependent upon seal water temp (due to the vapor pressure of the seal water).
Good luck.
What's the electrical consumption then?
Why not use an vacuum eductor/ejector system instead of a vacuum pump. Once you have started the system up it must be possible to generate steam using a WHB to drive the eductor.
