Teto
- Feb 16, 2002
- 16
Hi all,
I'm here from the mechanical side. Need help on understanding power consumption on a 3 phase induction motor. I was trying to calculate electrical cost of operation on a 3 phase induction motor. I used the formula Kw=V*A*1.73*PF/1000 for my calculations out of a electrician's pocket reference book. I then multiplied my Watt hours (hours of operation) by our utiliy's Kw rate. In this case I have 208V and 24 amps.
As I fiddled with the numbers in Excel and I asked around for a PF value I could use, It became apparent to me that I may not have a good understanding of how to calculate it, cost of operation. I say this because when I inserted a low PF value as opposed to a value closer to unity, I get a lower cost. If true, at 11.5 cents/Kwhr., ths motor will use 4.3KW at .5 PF and 6.9 KW at .8 PF. From what I remember reading, this cannot be right, as I thought the further away you get from unity (lower power factor), the more it should cost to operate the motor.
Do I have this right or have I missed something?
Also, if the power factor is unknown, is .8 good to use? One electrician said .15, that's not right is it?
Thanks for looking at this,
Teto
Teto
