racobb
- Feb 23, 2009
- 327
For the Utility Guys Here:
I have an issue where a fairly large (480 volt, 1200 kW) customer feels they have voltage regulation issues. PF averages 75 to 80%. The customer is served from 2 miles of 336 Al. OH line at 25 kV and a 2500 kVA padmount tx. We have recorded the voltage on 2 separate occasions at 1 minute intervals and found the service voltage to vary +/- 4 to 5 percent which we believe is pretty good and the levels are well balanced.
Probably a 3000 amp plus service.
Facility is located in the Southeastern US.
The problem appears that the customer has purchased some equipment that has a +/- 2% tolerance, to which we have told them that we could not gaurantee that level of swing on the system and they would need to install additional equipment to maintain their required level of voltage. The customer is asking for +/- 1% swing!
Aside from ideas anyone might have, I am also interested in others that have seen this issue and any equipment/mfg that might have been used to solve the problem.
Thanks in advance!
Alan
Alan
Thanks in advance!
Alan
Alan
