Power at 50Hz vs 60HZ??
jgalligan
1
We are going to be building some electrical resistance heaters for a project in England (50Hz). All prior woirk has been here in the US at 60Hz.
Besides the obvious adjustment for the different operating voltage, do I need to make any adjustment in my calculations to determine the heater power output and/or operating amperage to account for the lower 50Hz frequency? Will my amperage or heater power output change at the lower frequency?
Thanks.
If it is a pure resistance heater it won't acre whether it is AC or Dc, let alone whather it is 50Hz or 60Hz.
If however you have a fan motor in the heater you should take care to ensure that the motor is suitable for the 50hz supply. The fan will turn more slowly on a 50Hz supply than on 60hz and you will also have to account for this as well as the voltage/frequency change.
One day my ship will come in.
But with my luck, I'll be at the airport!
The total energy on resistive heater is
Heat(Watts) = Irms.Vrms=Idc.Vdc.
As ScottyUK mentioned above, the frequency do not have any impact on the resistance heater capacity.
Can I apologise for the number of typo's in my post:
acre = care
Dc = DC
whather = whether
I wish we had a spell-checker!
Dang! That looks pretty useful. Do you use it davidbeach?
I try to remember to use it on every posting. If you use it, you will have to add a lot of electrical terms to the dictionary, and it doesn't help at all with wrong words spelled correctly, but other than that I've found it to be a very useful tool.
jgalligan,
Another concern is going to be your controller for the heating elements. If it is SCR based, make sure it can be adjusted to the different frequency to that the SCR firing is not off. If it is just a contactor, make sure you have a 50Hz rated coil. Most 60Hz coils will work on 50Hz without much trouble, but some designs may be weaker and become problematic.
ScottyUK, no you are NOT forgiven yet. You must do pennance first. Repeat 5 Kirchoff's Laws, 3 Lenz's Laws and recite the Ohm's Wheel in Latin.
davidbeeh,
Great idea, except it would mean having to use IE, YUCK!
david,
Thanks. I will give it try.
jraef,
Pennance = penance?
See you at confession!!
Father forgive me, for I have sinned. It has been 37 years since my last confession. Since then my only sin is having misspelled penance.
Oh, and a few minor stretches of the truth...
?pinnace?
Good Luck
johnwm
________________________________________________________
To get the best from these forums read faq731-376 before posting
Steam Engine enthusiasts:
Gees!! I had the google tool and did'nt realize it worked so invisibly. Very cool! Thanks "Laplacian" Off topic but on the mark re spell check, thanks.
"skogsgurra" still wondering what penance is? It's what you pay or do, an act of contrition, confession, acceptances of punishment, absolution. Therefor to get back into the grace of god. It could amount to a few words of prayer or a whole lot more in some circles.
Here lets leave it to a few words. ok! and You've said them many a time, I'll be your witness. Thou shall be forgiven.
Am I feeling benevolent or what!!
pennpoint
