zlindauer
- Dec 27, 2010
- 35
I am working on a building that will be constructed using tilt up concrete sandwich panels. The geotechnical engineer has recommended a foundation consisting of a slab on grade stiffened with grade beams. I am trying to figure out if I need to use a pour strip for this type of foundation, or if I can simply create a deep wide ledge on the exterior beams to set the pannels on.
If I don't use a pour strip will the edge of the foundation be likely to be damaged during placement of the panels?
Is the pour strip critical to proper anchoring of the base of the tilt up panels, or are there acceptable methods that don't require a pour strip?
Is there a good resource you can recommend that would show various types of base connections between tilt up walls and their foundations?
Thank you!
Thank you!
