Good engineering practice dictates that the water network in a power plant used for kitchen, toilets, safety showers and eye-wash stations shall be separated from water networks connected to processes or lines under pressure conveying different fluids (eg waste under pressure, or chemicals) to avoid contamination of the "clean water network" described above.
Is there any standard describing a relevant requirement?
