Just a general question . . . I heard a contractor one time talk about doing the cladding on a 20+ story tower that had P/T Slab floors. He talked about how it was hard to get the cladding to line up from floor to floor as they went up the building, because the building would move back and forth as they applied the post-tensioning on each successive upper floor. It wasn't moving a lot, on the order of 1/4" I believe.
As I am getting into concrete p/t slab design using Ram Concept, I notice a hyperstatic lateral force in the reaction reports on shearwalls that can be very significant (depending on the layout of shearwalls, if shearwalls are not placed at the center of zero movement, for instance), and I am not quite sure what I should do with that force. Are you always supposed to design your shearwalls for the lateral force that the Post tensioning imparts to your structure? Does the post-tensioning impart a lateral force to your shearwalls, or does that lateral force get disipated somehow through restraint cracking.
