I am being tasked with coming up with a solution to repair a post-tensioned slab that has exposed and corroded tendons. The slab is 8 inches thick but I know nothing about the reinforcing / tendon location...etc. There are no existing drawings anywhere even in the city records, so I'm on my own as far as that's concerned.
My thinking in approaching this, is to have an inspection company x-ray the slab and determine the tendon layout, then based on that, maybe use Fiber Reinforced Polymer to reinforce the slab. While all this sounds easy, the difficulty lies in the fact that the slab is about 12 feet wide by about 200 feet long, and there are 10 levels with various degrees of slab damage.
So, my questions are:
1. Is my thinking legitimate? does FRP replace steel tendons?
2. Do I need to x-ray every square foot of the slab? or just a representative area?
3. Without any existing drawings or any information about the design, does x-raying the slab even do any good?
I am as you can tell not experienced with post-tension concrete and I am planning on teaming up with someone who does, but I just wanted to get a head start and find out some thoughts about this. So, any help would be appreciated.
