I've got an interior remodel in construction, single family home with a conventionally framed roof where we're taking out an interior wall below the ridge and replacing it with a glullam flush beam. Loads to 4x6 posts are around 6,500 lbs each. The 4x6's get buried into walls at each end (this is in the center of the home, not an exterior condition).
I do a lot of these kinds of projects, and typically specify a Simpson column base (CB46, CBSQ46, etc...).
The superintendent called on this particular house and of course they forgot to set the base before pouring concrete and now need a post set option (like a Simpson ABU46Z - something with an anchor that can be epoxied in to the footing).
My question is what is your normal thought process when selecting post base hardware for interior conditions like this? I know the ABU bases are good for over 10,000 pounds of gravity loads, but they just feel flimsy to me. Thoughts?
-Jason, Architect
-Jason, Architect
