dragonsaver
Materials
- Sep 10, 2003
- 8
We are looking at a new design of one of our products. We normally use 18.8 S/S bolt on the handle. It is treaded into a valve top which now has a 303 S/S insert. When there is a load placed on the valve and the handle is tightened to set the pressure, you can 'feel' a binding. When the threaded handle was removed, there were metal filings inside the top.
Question is should the insert be 18-8, or another material? Is this a problem with the softness of the material? Any suggestions?
