jimtheengineer10
One of the requirements for a pool at a rv park is that the re-circulation system has to be designed so that velocities do not exceed 6 fps. Based on the pools size and that the entire volume has to be circulated every 6 hours I have determined that the circulation rate needs to be 118 gpm. There will be two main drains connected to one 1-1/2" diameter pipe that runs back to the mechanical room. How would I determine the velocity in this pipe? Thanks in advance.
