RoarkS
- Jul 10, 2009
- 273
So round two... I'm clear of the first group, getting ready to hire another set of DER's but want to guide where this is going.
part 23 turboprop. aft of pressure bulkhead. I have the OEM FEA analysis results for the area.
-previously mentioned there is an existing hole done by the OEM near where I want to put my hole(s) that isn't addressed by the FEA I was provided. Their solution is a lot like the "porthole" I talk about below...
-The bays have a high aspect ratio... long stringers very narrow space, and wide frame spacing.
-The hole I need to poke needs to basically remove the skin from one of the bays entirely. I find this to be annoying because now every bit of guidance I have in front of me says cruciform patch, but the high aspect ratio of the bays makes it a BIG patch... which results in a shim, and the actual doubler. Lots of rivets, lots of paint. That said looking at some of the other BIG holes the OEM did, yeah there is a big doubler built under the frame's stringers, inside of the skin... so looks like pretty obvious guidance that's a path... but at that point I'm saying not economical for this mod.
-Looking at some slightly larger commuter cat aircraft on similar situations for environmental holes... reminds me of a naval ship porthole... basically a stringer formed into a hoop... but machined. What I'm thinking I want to do is cut one of the stringers, hole saw the skin, then rivet in this machined porthole, and splice it into the stringer. Could even machine louvers that could "carry the stringer through". ... I just need some basis for doing something like that. Would make install super easy and basically remove any external visual modification... except for the hole itself. Any suggestions for references? The predicted stress distribution is well within what the porthole can handle per FEA... just trying to find a method that isn't novel/I can throw some hand calcs at. //I have Niu on my desk now. Flabel and Bruhn in my bookcase at home...
