I am looking at a podium building - approx. 400' x 150'. 4 levels of parking below 8 stories of residential. The parking levels will be concrete - either cast in place or post tensioned. The upper floors are cold formed steel.
We will likely add an expansion joint in the building however I wanted to know if you were consider not having an expansion joint. I have seen some other building almost this size/length without expansion joints. I assume without an expansion joint you would need to consider some additional moment in the exterior columns due to either thermal changes and/or shrinkage. These would exist with or without the expansion joint but obviously larger without.
Any thoughts on this?
EIT
EIT
