I'm currently trying to design a circuit that will regulate the current/voltage go to and leavin an PMDC motor. A 24V PMDC motor turns a rotating cylinder and at certain points the motor then acts as a generator because the cylinder makes the motor run faster. So im trying to design a circuit that has some sort of a braking system. I only want to brake so keep the motor at a steady speed. Reverse current and voltage has burnt out many motors and power supplies and this circuit will hopefully fix the problem. i know i can use a controller but i just need a simple circuit with a zener and some other simple components......a simple voltage/current regulator......Thanks for all your help.....
