mac1992
- Jan 8, 2012
- 2
Recently arrived on a site in New Cumnock before the Christmas break, where, the week before, the engineer and external site foreman were unfortunately made redundant. As a 2nd year Site Engineer trainee (and having not worked under an engineer before), I was asked to take over to steady the ship until the Christmas break.
One of the tasks I am being asked to do however, is the plumbing of steel columns. I was just wondering what is the easiest/most accurate way of plumbing steel columns for a single-storey gymnasium.
A method that I thought of was to set-up using the total station and on each base plate of the column in the 4 corners mark off-set centre points (250 mm Northing and 250 mm Easting offset for instance)and then alter the co-ordinates of the local grid to suit the offset. Then, take a reading of the offset marks made on the columns to get a position of the column and line in the 4 corner columns. Then line the rest of the outer columns in using the 4 corner columns which are in the correct position (hopefully) using the theodolite, before lining the inner columns in using the outer columns, again using the theodolite.
