Beams Under Combined Axial and Transverse Loads - Beam Columns
Eng.Rami
Hi
I'm trying to design a reinforced Beam Under Combined Axial and Transverse Loads - Beam Columns does anyone have a reference or example to design it and what are the design limits for that I searched a lot and I only found steel beams and I need an RC beam
thank you
ACI
Doug over at likes that kind of stuff
You might even find a free spreadsheet to help you out.
He has some nice ones. Check his blog post listings.
There are many resources out there showing how columns are designed using the classic P-M capacity curves. This is basic column design shown and derived in any concrete textbook.
Thank you JAE
But in my case it doesn't have the top steel reinforcement so it couldn't be solved as a normal column it's a beam column element
