PLS CADD spanish criteria file
ES
Hi. I´m new at using PLS CADD. I can't find any criteria file with spanish code for loads in the version of the program I have. Could anyone send me the proper criteria file or should I have to créate it from de begining?
Thanks.
Did you check their web site for some different criteria files? They have libraries of a lot of component files. I don't do any Spanish design things and if it is not on their web site, you will probably take the criteria for the part of the USA that closely resembles your project's location and make changes to the CRI files to suit your situation.
I was at the last User's Group meeting and there were Engineers from all over the world there. You might more help if you post the question in the group "Transmission structure engineering" because the T-Line stuff probably belongs there instead of a General Engineering topic. T-Lines are definitely a very special topic.
_____________________________________
I have been called "A storehouse of worthless information" many times.
I checked with PLS support and they do not have a specific CRI file for Spain, so you will have to develop your own.
