Hello everyone,
I'm working on a project at my house and looking to use plexiglass or similar polycarbonate. I am using the materials to cover up two window wells to the basement windows. The 2 openings measure approximately 49"x32" and 49"x34". The plexiglass will be affixed with clear caulk to treated lumber on 3 sides of the opening with approximately 1.5" lip, and butted up against the brick facade of the house on the 4th side. There is a slight slope up to the house for rain water to run off(approximately 8 degree slope). One additional consideration, currently the window wells are being covered by half inch sheets of plywood. I have 2 large dogs(100-120 pounds each) that have taken to laying on top of the plywood. Because of this I am wondering if there is a material or thickness you could recommend that could withstand the weight of a large dog standing on it. Hoping they will stop this habit once the plywood is removed and clear plexiglass is installed, but trying to prepare to avoid and potential hazards.
Thanks for the help here!
