Hi Everyone,
I'm not a structural engineer and I need some help checking a design for a welded gusset. I've pasted a drawing below. I have a cantilever beam supported by 2 gussets from above and 2 from below. The gussets are welded to a steel column and to a piece of square tubing. There are two point loads of about 300lbs each at 24in and 50in from the column to which the gussets are welded (ignore the weight of the beam). The square tubing is welded to the gussets perpendicular to the column and is otherwise unattached. The gussets will be made from .25in thick HSS. Assuming they are 45deg gussets (can change if necessary), I need to know how large they need to be. More specifically I'm trying to figure out how long the welds need to be.
http://postimage.org/
imag
Thanks in advance for the help.
-b
imag
-b
