aniket79
- Aug 11, 2010
- 6
Hi every one.......
I am facing problem with thin plate bending using ANSYS 11.0. Plate dimensions are as 180X120X0.7 mm(LxWxt). I want to bend this plate in 90 deg at length 30 mm from both ends to make c section and radius of bend should be 3mm. I tried it by using shell93 and shell181 but I got only 15 to 20 deg deflection approximately.
If anyone could help me I'd appreciated.
here is the code that I used for ansys analysis
finish
/clear
/prep7
/title, bending
!key points
k,1,0,0,0
k,2,50e-3,0,0
k,3,90e-3,0,0
k,4,120e-3,0,0
k,5,120e-3,0.7e-3,0
k,6,90e-3,0.7e-3,0
k,7,30e-3,0.7e-3,0
k,8,0,0.7e-3,0
! lines
l,1,2
l,2,3
l,3,4
l,4,5
l,5,6
l,6,7
l,7,8
l,8,1
!key point for circle
k,9,30e-3,3.7e-3,0
circle,9,3e-3,,,360
al,1,2,3,4,5,6,7,8
al,9,10,11,12
lesize,1,0,,10,1.0
et,1,shell93
r,1,0.7e-3
mp,ex,1,210e3
mp,prxy,1,0.3
esize,,0.1e-3
amesh,all
dl,2,1,uy,0
dl,2,1,roty,0
dl,3,1,uy,0
dl,3,1,roty,0
dl,4,1,uy,0
dl,4,1,roty,0
dl,5,1,uy,0
dl,5,1,roty,0
dl,6,1,uy,0
dl,6,1,roty,0
dk,2,uy,0
dk,2,roty,o
dk,7,uy,0
dk,7,roty,0
da,2,all
sfl,1,pres,10e3
/solu
antype static
solve
finish
/post1
plnsol,s,x
thank you
Aniket
finish
/clear
/prep7
/title, bending
!key points
k,1,0,0,0
k,2,50e-3,0,0
k,3,90e-3,0,0
k,4,120e-3,0,0
k,5,120e-3,0.7e-3,0
k,6,90e-3,0.7e-3,0
k,7,30e-3,0.7e-3,0
k,8,0,0.7e-3,0
! lines
l,1,2
l,2,3
l,3,4
l,4,5
l,5,6
l,6,7
l,7,8
l,8,1
k,9,30e-3,3.7e-3,0
circle,9,3e-3,,,360
al,1,2,3,4,5,6,7,8
al,9,10,11,12
lesize,1,0,,10,1.0
et,1,shell93
r,1,0.7e-3
mp,ex,1,210e3
mp,prxy,1,0.3
esize,,0.1e-3
amesh,all
dl,2,1,uy,0
dl,2,1,roty,0
dl,3,1,uy,0
dl,3,1,roty,0
dl,4,1,uy,0
dl,4,1,roty,0
dl,5,1,uy,0
dl,5,1,roty,0
dl,6,1,uy,0
dl,6,1,roty,0
dk,2,uy,0
dk,2,roty,o
dk,7,uy,0
dk,7,roty,0
da,2,all
sfl,1,pres,10e3
/solu
antype static
solve
finish
/post1
plnsol,s,x
thank you
Aniket
