If you design this device as new, I suggest you have the teeth number arranged this way:
z1+2*z2+1=z3
(z1+z3)/n=integer this equation I have mentioned above
z1 number of teeth of sun gear,
z2 number of teeth of planet gear,
z3 number of teeth of ring gear,
n number of planet gears, placed in equal angle.
The first equation seems not right, but that gives sun gear room for positive profile shift coefficency.
14.5 PA, that doesn't make sense for winch, if that is only to avoid undercut of sun gear, the designer didn't think of the sun gear much.
