RedCoat999
I have been tasked with designing a 10000 rpm to 5000 rpm planetary reducer. Output load is about 9 HP. It has to fit inside a 4 inch diameter. Are there any particular pressure angles, diametral pitches to use/avoid?
Will this need any lube for short <1 hour running times?
How is the efficiency determined?
Thank you.
Thank you.
