I have a project with a retaining wall that is approximately 13’ tall. Due to some so constraints onsite the contractor needs to place this wall in lifts and is asking if this is OK. The wall is 14" thick and has an inner and outer layer of steel. Both layers are designed as if the wall was a cantilever wall (outer layer) or propped at the top (inner layer).
The only downside I can think of has to deal with the shear transfer through the cold joint between concrete lifts. Here we could intentionally roughen the surface and then provide additional reinforcing at the joint (the dreaded shear friction). Are there any other downsides?
I can’t believe I have never run into this before.
