Piping Stress Analysis requirement for Operating Temperature of ambient piping at 45 deg. C
mechnas
7
Pipe stress analysis is required for process piping under temperature having significant expansion. However, if the piping process temperature is 45 deg. C for the cross country piping having length of about 6,500 meters, whether stress analysis is required as per code. Please also advise if the major portion of the piping to be laid under ground.
First off which code are you using for your buried piping?
Second, it probably doesn't matter because all codes require you to calculate the stresses the pipe is under during operation.
One of those stresses is thermal expansion.
Therefore it is required. Now how detsailed you make tht analysis is a different question and that will depend on your routing, your design, the material, the soil, the installed temperature etc etc.
The pipeline design codes have simple calculations for retrained and un restrained pipe.
If you have a process fluid of 45C, experience tells me that there shouldn't be a bi general issue, but you're getting close to the limit where it might be in a particular location where other stresses or bending occurs.
So, IMHO, your opening sentence "Pipe stress analysis is required for process piping under temperature having significant expansion" is not correct. Stress analysis is required for ALL process piping, but if there is no large expansion then there shouldn't be a big issue and you might be able to do it quite simply and in a straightforward manner.
just noticed your discrepancy - title says 48C, post says 45C. which is it??
My pleasure.
So what are you going to do now?
These forums work best when you engage with the response....
Also pipe expansion needs to include the full range from lowest pipe temperature to the highest. Big different between -10 to 48C and +25 to 48C.
