Piping Question..
cp3
53
As you can see from the jpeg, Im trying to use the "Swept Boss/Base" command to draw a pipe going both directions once it reaches the end, but the command wont let me. How do I draw a pipe going in both directions? Is there a command I should be using instead of the Swept Boss?
One Sweep = one profile + one path.
To create a branch or Tee, a second sweep is needed.
