ly1phil
- Jun 11, 2008
- 13
Here’s the piping/pump problem…
I’m leaving out some details in order to simplify the problem in order to explain it.
I have 3 heat exchangers that have cooling water provided from one pump. These heat exchangers are at different elevations, for simplicity say they are at elevation 10ft, 20ft and 30ft above the centerline of the pump discharge. Currently all three heat exchangers discharge into a common discharge line located at elevation 15ft.
If I were to add a section of pipe within the common discharge line but before the pipe exit point (i.e. the point of discharge is still at 15ft) that resembled a upside down U, with the top of the U at elevation 25ft, would the pump see an increase in the system’s pressure if I disregarded frictional losses because they are negligible.
The “loop” would start at the 15ft elevation climb vertically up to the 25ft elevation and back down to the 15ft elevation then to the exit point.
I am unsure as to how much this will affect the system pressure that the pump sees. Will it add 10ft H2O of backpressure to the pump? Or can I neglect the height downstream of the highest point (30ft) and assume it is free flowing at that point? Any ideas would be appreciated. Thanks.
