Hi All,
I am currently designing uPVC Sch80 chemical dosing lines containing Sodium Hypochlorite (0.8%) and am trying to understand how to properly derate the PVC (and find the temperature rise in the pipe) for the following options:
[ul]
[li]Buried concrete box culvert - nominal depth 450mm[/li]
[li]Direct buried - nominal depth 750mm[/li]
[/ul]
The fluid temperature leaving the building will initially be 25degC, but will be pipe approximately 200m to a dosing point, with the pipe being laid in either of the two options.
The ambient temperature will be around 49degC, so I am currently unsure how to calculate the rise in temperature inside the box culvert. Am I right to assume that the temperature in the box culvert will eventually rise to the ambient air temperature, or will the box culvert alleviate the temperature slightly?
I have been quoted that the soil at the 750mm burial depth will be a constant 35degC. So believe that the max fluid temperature the second option would rise to is also 35degC.
Any help or direction in this matter would be greatly appreciated.
[ul]
[/ul]
