Melzar
- Apr 1, 2008
- 10
I'm working on a small residential job on a lake. There is marl to a depth of about 30 ft, sand 30-45 ft, very soft clay (w.o.h.) to 65 ft, then alternating sand and soft clay layers. I'm considering driving closed-end pipe piles to bear in the lower sand and clay layers but am concerned about possible artesian conditions and piping around the piles. Artesian conditions are known to be present in the area based on nearby water well records. The adjacent residence bears on helical piers that went to 50 ft without a problem.
We drilled HSA as deep as 60 ft, but for our deep boring we set casing and rotary drilled to 140 ft. We did not have any flow for our HSA borings, but the geotech boring next door had flow with an explored depth of only 35 ft.
Should I feel comfortable that the soft clay will seal itself? Anybody have any lessons learned? The usual sources don't seem to offer much in the way of guidance.
