Pipe Welding 5
QCMike
Petroleum
CA
Can two welders qualified to deposit 14mm max. weld one pipe joint with a 25mm wall?
If a welding symbol calls for a single bevel on both sides of a 20 mm plate and the preperation calls for 10mm on both arrow side and opposite side, is it calling up a full pen weld? There is no mention GTSM in tail.
It sounds like a full pen weld to me. If the root was made with GTAW or GMAW, backgouging may not be required.
This is a typical discussion when trying to decypher a WPS written to meet ASME Section IX and applying it to a construction code such as B31.3 or Section VIII.
You can write a WPS that meets Section IX, but not the applicable construction code. You can write a WPS that meets both the construction code and Section IX that still doesn't meet the practical needs of the welder.
Case in point: The procedure is qualified using an austenitic stainless 304 alloy using a 308 filler metal. Now the user wants to weld a 316 alloy, does he use a 308 filler metal because it was used when qualifying the WPS or does he use a 316 alloy filler metal?
ASME isn't going to answer the question. You will have to search literature from other sources because ASME doesn't tell you "how to do anything". I'm not saying that is a bad thing or a good thing, it is simply the ASME approach to welding as well as other "how to questions".
Many of the answers to welding related issues can be found in literature available from AWS. Many of the individuals that sit on the AWS committees also sit on ASME committees.
Best regards - Al
