koba78
Petroleum
- May 10, 2011
- 30
Dear Sir/Madam
I have created a simpe Excel tool (hardy cross method) to calcuate the water distribution through a network.
But, our project is required to develop a cooling water network with seven coolers(supply and return pressure, delta P / elevation of each cooler and pipe rack) has been given, and boost pump may be required to be used if the pressue head of the end user is not sufficient .
It's quite complicated, and seems can't be used this simple excel progam to work out.
I tried to use pipe flow 3D progamto give it a try and I wonder any pro got any pipe flow 3D tutorail or better sugeestion for this case.
Thank you very much.
