SansengMech
The ASME Sec VIII Division 1 Mandatory Appendix 2 'Rules for bolted flange connections with ring type joints' does not consider additional tension or bending moment but only pressure, internal or external. I observed that people used pressure equivalent method alsong with this to check flanges (thread378-18541 We have ASME Sec VIII Division 2 Para 4.16 'Design Rules for Flanged joints' and here both the external loading, additional tension as well as bending moment are considered. The question is why then we have to go for Div1 method along with peq instead of Div2 method all the time? Also, for API 6B and 6BX flanges, can we use ASME Div 2 method in addition to API 6AF, 6AF1 and 6AF2 methods?
