Pipe bending
  • Thread starter Thread starter rakic
  • Start date Start date
R
rakic
Guest
Hello guys. I need to make pipe like from the image but not
with the sweep option, but with the bend because I need
step by step bending for operational technical drawing.
Each drawing for each bend separately. Can you tell me what
option can I use and how to use it?
ThanksView attachment 5773
Piping would be a good option, under Applications>Piping!
You can find info on operation under Help . Functional Area >Piping Modules and Books . Piping
Have a look at this sample model i made. I've used some relations in sketches, which calculates the length of the pipe. I'm using two spinal bends, each adding a bend to the pipe.
the file is in creo 2.0 version
hKMU4m1XlMe1Rjjb3Bzq0HNDrs4QQFrexcBq6p3GptXMdmevpPWmwHzvWIG1ZSdLKg9j2Hwrx-s
Edited by: solidworm
Hello solidworm. Thanks for your reply. I cannot open files
because I use older version in ProE Wildfire 4.0. I should
told you in my first post what version I am using. Can you
convert it to older version?
Thank you again.
If it would be easier for you send it on rakicm@gmail.com
