Are there any of the shelf connectors that can change pinouts by twisting them. I am looking to the change wiring configuration on a cable by utlizing a connector in the middle that I can either twist or pull and then twist to change the pinout. For example if I have pin A from one end going to pin 2 on the other end, i would like be able to twist a connector in the middle where now Pin A will be going to Pin 1 on the other end.
