Pin in Shear
DBCox
Automotive
Hello all.
I have a question about stress concentration factors in a ductile pin. In order to calculate the pin diameter in perfect shear, I have always used the crossectional area and load to determine the average shear stress in the pin and design to that.
I know there is some increase in the stress on the side of pin where the force is applied (I'll call that the front), but I have always considered it to be neglible in ductile materials. Someone recently told me they assumed the local stress there is 5 times higher than the average, which seams a little overkill.
Is this stress concentration on the "front" of the pin a consern? Is it really 5 times higher?
If you have a static load on the shear pin then your approach is fine. If you have a cyclic load that a stress concentration factor should be included. A factor of five appears excessive unless you have "jerks or impacts" in the loading of the pin.
