MechEng1977
Automotive
If I have a pin hole in a anti-corrosion paint, will corrosion be accelerated in the area where the pin hole occurs.
The paint is applied to a 1080 Rail Steel.
The Steel is currently corroding quite rapidly, and one of our ideas is to coat the steel with a anti-corrosion paint. One of the team members is concerned if there is a pin hole in the protection due to mis application or handling, the Rail will rapidly corrode in that area.
My thoughts are yes it will corrode in that area, but it won't spread and it is better than the entire rail base corroding as it is now.
Thanks in advance
Thanks in advance
