We are planning to built a compact wastewater treatment building with a wide spread foundation extended over a 100m x 40m rectangular area. All process tanks are concrete. The depth of building below grade will be 2.5m. The total weight of the building is approximately 20000 tons.
We first wanted to see what would be the pile carrying capacities are and tried to drive 400x400 square 12m long concrete piles... However the piles could not be driven more than 5 meters.
What would you be your thoughts?
Forget about piles and make a compacted bed and build the structure on top of it?
Attached is the borehole profile. We had 8 boreholes and all are the same.
