swertel
- Dec 21, 2000
- 2,067
Please help out a mechanical engineer interpret this electrical verbiage.
I have an assembly that uses a Piezo element in it to excite a component upon impact. The specification requires that it
What is that in terms of Voltage, Amps, or Watts?
The disc is .7 inch diameter by .1 inch thick per MIL-P-12815 if that helps.
I'm trying to test the component that gets energized by the piezo without destroying a bunch of piezo elements in the process. Thus, I need to know how much energy the piezo actually gives off so I can reproduce it using another supply source.
--Scott
shall supply electrical energy equivalent to that discharged by a 0.005 microfarad capacitor that has been charged to 9 volts, minimum, when impacted by a 1.94 ounce steel ball dropped from a height of no greater than two inches (2”)
--Scott
