enverd
- Oct 25, 2010
- 47
I am faced with an undervoltage problem at work where some Air Handling and Exhaust Fan unit, while being fed through VFDs, are tripping breakers. The monitored voltage indicates an ongoing AB = 415V, BC = 417V and CA = 475V.
I am thinking that there might be issues with the VFD, control power transformers or IGBT's that could have an effect on the voltage. Comparing the read voltage levels it also seems as if phase B has some type of a fault.
One of the engineers at work suggested that I look into phase angle displacement that could create an undervoltage problem?
However, even though this should possibly be already clear to me, I am having a hard time putting together a phase angle displacement effect on undervoltage?
Is there a relationship and how would it affect it?
Also just in general any suggestions what the problem might be?
Thanks in advance.
Thanks in advance.
