Due to evaporation and recycle, depending upon your washing system's blowdown and make-up water flow rates (cycles of concentration), you may find that pH actually rises due to concentration of make-up water alkalinity. What you are washing out will also be of importance, no doubt.
Tough when you dont have samples ... or know what you are washing.
Nonetheless,pH control of clarification itself (your recycle stream is feedstock) is a useful parameter (re its affect on coagulation and flocculation and clarification performance). Having a small plastic diaphram metering pump to feed diluted caustic (from tote or barrel), or H2SO4, if anything, or as your needs may dictate, is not a big deal. Perhaps just make sure that you have room for it at a later date.
You likely may also need to chlorinate, with alkaline bleach or acidic Cl2 gas, for example. So leaving room for pH adjustment wouldnt hurt, yes.
Titrate samples when the plant is running .. then add the pH control?
How about assuming 20% of system volume make-up each week, with blowdown of water with zero alkalinity, and size based on neutralizing make-up water alkalinity ... like, with acid. Like a cooling tower.
Just a thot....
