Dear Sirs,
I would like to ask some advice on persuading my mechanical engineer co-workers that plate exchangers reliability is not a significant issue. I have recently tried to convince my co-workers of using these but came up with the following obstacles.
Duty was oily fluid cooling from 130 to 40 deg C with process water.
1) The plates are only 0.5mm thick - so how do you know they wont stress crosion crack ?, because spirals are thicker it is thought they would be ok?
> This meant we needed to consider titanium or hastalloy - getting two complext and expensive.
2) Plates suffer from sealing issues. Theres a risk that they wont seal and contrinue to drip.
3) Plate exchangers can just "Ping" open - with the whole plate pack just opening - this is a safety consern. Because just 4 bolts are holding the pack together !. I've not heard of this but they apparently think this has happened. So with 130 deg C oil an obvious safety consern !.
4) Process water fouling. In the past at our facility we have fouled process water exchangers due to high wall temperatures (above 50°C)- with a plate this is thought to be worse - is this true ? In addition conserns are raised about on-line cleaning - it is thought that using an acid cleaner could cause localised corrision in dead spots on the exchanger ??
I would appericate any feed back or links to other sites.
James Bruce
James Bruce
