Penstock design for Microhydro
tecnico
NZ
I am looking for a simple set of formulas or program to size up pipeline diameter, flows, friction losses. Using steel pipe and HDPE.
Cheers
If you are in the USA you may not be able to access this but otherwise you could try
"Internal Flow Systems" by Don S Miller, British Hydromechanics Research Association (BHRA) Information Services, 1986.
Regards, David.
For penstocks look to the American Water Works Association Standard, AWWA M-11. Also the American Iron and Steel Institute has at leat one Penstock publication (and 3 other associated piping pubs). Also the US Bureau of Reclamation has many publications that will provide good input for you.
Regards, John.
Get "Steel penstocks" manual N° 79 from ASCE (ISBN 0-87262-951-1) (More than 400 pages). Is quiet complete en the topic.
Good luck.
