See attached photo. The beam, in particular the bottom flange, is twisted noticeably to the right.
Overall there was no heat damage or buckling observed in this building. End walls blew out including the columns, but all frames in this area were ok. A lot of collateral damage and soot but members are straight. Is it possible that this visible twist was present before the fire?
Easiest fix to just replace? Heat straightening?
